YTsuj6's avatar
YTsuj6
6 years ago
About pin processing of unused input pins for Cyclone V.
FPGA:Cyclone V (5CEBA7F23C7N)
Can I use the input setting IO pin in the open state when it is not used?
There is a model where the FPGA circuit is common and the external circuit is different, so the settings are common.
  • sstrell's avatar
    sstrell
    You can also set this on an individual pin-by-pin basis using the Pin Planner. Right-click a pin in the Package View, go to Reserved Pins, and select an option.
    #work4intel
  • ShafiqY_Intel's avatar
    ShafiqY_Intel
    Hi YTsuj6,
    The Unused Pins must connect as defined in the Quartus Prime software.
    Below are the options for unused pins:
