lambert_yu's avatar
lambert_yu
6 years ago
About pad scheme of i3c prototype on fpga
Hi all,
I want to build one i3c prototype on fpga, but I find that all pins can only used as one of the push-pull or open-drain, I don't find that one pin can switch drive mode between push-pull and open-drain, anyone can provide me some advice, thanks.
Lambert
  • ak6dn's avatar
    ak6dn
    You'll find in FPGAs the operating characteristics of a pin are not dynamically settable (ie, LVCMOS vs LVTTL vs LVDS, etc), dynamic pullups, bus hold, totem-pole vs open collector. They can be programmed at startup but are hard (but not necessarily impossible) to change dynamically.
    A driver enable can enable/disable the driver function, but it is an all or none option.
    Simplest is probably to assign two adjacent pins, an open collector driver with enable, and a totem-pole driver with enable. Then chose one to sample input on, and enable one driver or the other as needed.
    • Lambert's avatar
      Lambert
      Hi ak6dn
      So maybe I can use this method currently, and will such pins appear in new FPGA models in the future?
      B.R,
      Lambert
      • ak6dn's avatar
        ak6dn
        Since I don't work for Intel/Altera, I can't make any comment on this other than 'not likely', in my opinion.
        The usage scenario is quite small for this feature, and using two pins vs one is not a big deal in that case.
        It is not like you are going to build a controller that needs hundreds of 'I3C' interfaces.
  • Hi,
    May i know what is the device number for the FPGA?
    Aiman
    • lambert_yu's avatar
      lambert_yu
      Hi airman,
      I have cyclone v, arria v, arria 10, cyclone 10 board, but I don’t find which one can fulfill my need, or can you provide some advice or fpga kind which can resolve my problem, thanks.
      Lambert
