M_Goto
5 years agoabout Internal Weak Pull-Up(cyclone10LP)
Tell me about the Internal Weak Pull-Up of cyclone10LP. For before and during configuration, is weak pull-up enabled regardless of the weak pull-up resistor setting?
best regard
- 5 years ago
"The user I/O pins and dual-purpose I/O pins have weak pull-up resistors, which are always enabled (after POR) before and during configuration."
Pull-up resistor is disabled by default in user mode.
Value of pull-up resistor depends upon VCCIO voltage.
See R_PU value in Table 11.
Ash_R_Altera
5 years agoHi,
