12 years agoabout FIR compiler
why FIR compiler have the limit on the number of the coefficient set in use of multiple coefficient sets's function.Is it because of the resource of the hard ware or others reason?who can tell me ,th...
12 years ago --- Quote Start --- if i use multiple parallel stage ,each with a FIR compiler,is that ok in the situation when the total number of coefficient are out of the limit on single IP and each stage are not? --- Quote End --- If resource helps it should be ok then you have to mux the relevant ip
