16 years agoabout EPM240 high impedance output
im now encounter a problem with EPM240 high impedance output,it seems like the io port has connected a low value R to the ground that drop down the voltage provided by other signal on the bus. ...
16 years ago1'bz means the IO is open circuit to the bus,so the valtage has nothing to do with the IO.You can try on the hardware.
