16 years agoabout EPM240 high impedance output
im now encounter a problem with EPM240 high impedance output,it seems like the io port has connected a low value R to the ground that drop down the voltage provided by other signal on the bus. ...
16 years agookay green and violett are what you want to have but red is what you get on your implementation ... a bit far away ...
the red lines might indicate some RC behavioral that it is not fast enough if it is due to quartus setings, maybe somebody else could help you more but probably would need your project settings (qsf file).
