16 years agoabout EPM240 high impedance output
im now encounter a problem with EPM240 high impedance output,it seems like the io port has connected a low value R to the ground that drop down the voltage provided by other signal on the bus. ...
16 years agowont't you need some termination resistor between A and B ? like 150Ohm or something matching to your cable ?
no neet a termination resistor, cause its just p2p. ---------------------------------- the waveform are right.......... the wrong waveform show as the red lines the attachment with the operation. assign aup=adjlevel?1'b0:1'bz; assign bdown=adjlevel?1'b1:1'bz; --------------------------------------- i think its about the IO resource configuration of MAXII device ,....... ---------------- thanks a lots
