16 years agoabout EPM240 high impedance output
im now encounter a problem with EPM240 high impedance output,it seems like the io port has connected a low value R to the ground that drop down the voltage provided by other signal on the bus. ...
16 years agojust to understand you a bit more
So the green line is A and the violett line is B during adjlevel = 1 A is max 3,3V as this is the EPMs IO voltage and B is 0V A can't reach 5V as the pull up won't be feed with 5V during adjlevel = 0 A and B are around 2V +/- something so you would expect A and B going from 0V to 3,3V what is not the case and you assume 1'bz not working and the blue signal shows a correct waveform ? 80nsec = 12,5MHz ? that clock should be seen between A and B during 1'bz wont't you need some termination resistor between A and B ? like 150Ohm or something matching to your cable ? What about the other side of the RS485 can it drive a 12,5MHz clock ?
