16 years agoabout EPM240 high impedance output
im now encounter a problem with EPM240 high impedance output,it seems like the io port has connected a low value R to the ground that drop down the voltage provided by other signal on the bus. ...
16 years agois your intension to use the epm pins aup and bdown to enable or disable slightly forced rs485 levels into idle levels ? to enshure proper 0 and 1's when not using the rs485 bus ?
your schematic (altium designer?) mentions 5V does this mean your rs485 bus runs at 5v levels between a and b line ? in addition i fully agree with FvM that you should realy take care about the rs485 levels as the epm240would withstand the emc like a bulletproof 15KV MAX485EESA tranceiver. between your adlevel 1 -> 0 -> 1 transitions, there seems to be reflection on a and b due to unterminated signals if i interprete these staircases correctly. but what does the blue line mean ? is it the input signal from your tranceiver ?
