12 years agoabout decimation
why do we need decimation in DDC,before the data go into the FIR digital filter,whose rate is fast.assume that the sample rate is 105MHZ,the single bandwidth is 40MHZ,if i need FIR to select 8MHZ's ...
12 years ago --- Quote Start --- why do we need decimation in DDC,before the data go into the FIR digital filter,whose rate is fast.assume that the sample rate is 105MHZ,the single bandwidth is 40MHZ,if i need FIR to select 8MHZ's bandwidth from 40MHZ, is it ok,can the fir permit fast clock rate?how fast rate the fir can work. --- Quote End --- Your questions are far from clear. In a DDC you normally receive signal at high sample rate e.g. 105Msps (if I understood you). Your target sampling rate is then decided by what signal you are working with. If your final signal bandwidth is 8MHz(complex) then a sampling rate of 8Msps may be what you aim at. This should cover +/- 4MHz provided your signal is around 0 frequency(baseband).
