about DDR3 init ,god please
- 1 year ago
Hi
I think the signal tap cannot capture the signal from mem* conduit since it connected to the memory component.
Therefore, you may not see the signals are triggering in the signal tap.
You may refer to the simulation test run to observe these signals behavior.
I think the memory datasheet may has some description in the power up and initialization of memory section that you can refer to.
Adzim
Do you have any further question in this case?
Adzim
- zhangxianyu1 year ago
I actually tested DDR3_resetn and DDR3_cke on the oscilloscope, and these two signals were indeed DDR3_resetn pulled up first, and DDR3_cke pulled up after 500us. However, my DDR3 still fails to initialize. Do you think all DDR3 signals need to be of equal length, because my cas/ras and other control signals are not as long as the data signal
