11 years agoAbout converting two sof files to one jic file
Hi, I encountered some difficulties in creating jic file and need help. I have two sof files and two jic files generated based on the sof file, either one jic works well after I program it into EP...
11 years agoHi, Stewart, thanks a lot!
apologized for duplicating question.. About the address, I'm sure they are not overlaped because I checked the generated map file. in fact, I use EPCS64 in my design, but I just post the image found in my computer, sorry for causing misunderstanding.. My another question, is remote update module is necessary for the two sof files case? e.g. if the factory image contains a remote update module, but there is no remote update module in app image, if force reconfig the app image, can the app will be loaded successfully?
