JLIU45's avatar
JLIU45
2 months ago
About ALTIOBUF simulation
I'm trying to use the IP ALTIOBUF for input delay, but simulating failed, and the error message is: Bad default binding for component instance "ioconfiga : cyclonev_io_config".# (Component port "padtoinputregisterfinedelaysetting" is not on the entity.). I'm sure I've added all the necessary libraries(altera_mf, primitives....), and the device in use is cycloneV, my quartus version is 17.1, so is there anybody who have used this IP? In addition, who can give the timing diagram for this IP? thanks
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    May I know if you are able to share your design file for me to take a look? If yes, I will contact you privately.
    Aqid
    • JLIU45's avatar
      JLIU45
      thanks Aqid, in fact I'm trying to simulate the IOBUF, which is generated by IP catalog, and compilation cannot pass, attached is the generated file, FYI.
      -- megafunction wizard: %ALTIOBUF%
      -- GENERATION: STANDARD
      -- VERSION: WM1.0
      -- MODULE: altiobuf_in
      -- File Name: IN_delay_buf.vhd
      -- Megafunction Name(s):
      -- altiobuf_in
      -- Simulation Library Files(s):
      -- cyclonev
      -- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
      -- 17.1.0 Build 590 10/25/2017 SJ Standard Edition
      --Copyright (C) 2017 Intel Corporation. All rights reserved.
      --Your use of Intel Corporation's design tools, logic functions
      --and other software and tools, and its AMPP partner logic
      --functions, and any output files from any of the foregoing
      --(including device programming or simulation files), and any
      --associated documentation or information are expressly subject
      --to the terms and conditions of the Intel Program License
      --Subscription Agreement, the Intel Quartus Prime License Agreement,
      --the Intel FPGA IP License Agreement, or other applicable license
      --agreement, including, without limitation, that your use is for
      --the sole purpose of programming logic devices manufactured by
      --Intel and sold by Intel or its authorized distributors. Please
      --refer to the applicable agreement for further details.
      --altiobuf_in CBX_AUTO_BLACKBOX="ALL" DEVICE_FAMILY="Cyclone V" ENABLE_BUS_HOLD="FALSE" NUMBER_OF_CHANNELS=1 USE_DIFFERENTIAL_MODE="FALSE" USE_DYNAMIC_TERMINATION_CONTROL="FALSE" USE_IN_DYNAMIC_DELAY_CHAIN="TRUE" datain dataout io_config_clk io_config_clkena io_config_datain io_config_update
      --VERSION_BEGIN 17.1 cbx_altiobuf_in 2017:10:25:18:06:52:SJ cbx_mgl 2017:10:25:18:08:29:SJ cbx_stratixiii 2017:10:25:18:06:53:SJ cbx_stratixv 2017:10:25:18:06:53:SJ VERSION_END
      LIBRARY cyclonev;
      USE cyclonev.all;
      --synthesis_resources = cyclonev_delay_chain 1 cyclonev_io_config 1 cyclonev_io_ibuf 1
      LIBRARY ieee;
      USE ieee.std_logic_1164.all;
      ENTITY IN_delay_buf_iobuf_in_3jr IS
      PORT
      datain : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
      dataout : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
      io_config_clk : IN STD_LOGIC := '0';
      io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0) := (OTHERS => '0');
      io_config_datain : IN STD_LOGIC := '0';
      io_config_update : IN STD_LOGIC := '0'
      END IN_delay_buf_iobuf_in_3jr;
      ARCHITECTURE RTL OF IN_delay_buf_iobuf_in_3jr IS
      SIGNAL wire_sd1_dataout : STD_LOGIC;
      SIGNAL wire_sd1_delayctrlin : STD_LOGIC_VECTOR (4 DOWNTO 0);
      SIGNAL wire_ioconfiga_padtoinputregisterdelaysetting : STD_LOGIC_VECTOR (4 DOWNTO 0);
      SIGNAL wire_ibufa_o : STD_LOGIC_VECTOR (0 DOWNTO 0);
      COMPONENT cyclonev_delay_chain
      GENERIC
      sim_falling_delay_increment : NATURAL := 10;
      sim_intrinsic_falling_delay : NATURAL := 200;
      sim_intrinsic_rising_delay : NATURAL := 200;
      sim_rising_delay_increment : NATURAL := 10;
      lpm_type : STRING := "cyclonev_delay_chain"
      PORT
      dataout : OUT STD_LOGIC;
      delayctrlin : IN STD_LOGIC_VECTOR(4 DOWNTO 0) := (OTHERS => '0')
      END COMPONENT;
      COMPONENT cyclonev_io_config
      GENERIC
      enhanced_mode : STRING := "false";
      lpm_type : STRING := "cyclonev_io_config"
      PORT
      dutycycledelaysettings : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
      ena : IN STD_LOGIC := '0';
      outputenabledelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
      outputfinedelaysetting1 : OUT STD_LOGIC;
      outputfinedelaysetting2 : OUT STD_LOGIC;
      outputhalfratebypass : OUT STD_LOGIC;
      outputonlydelaysetting2 : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
      outputonlyfinedelaysetting2 : OUT STD_LOGIC;
      outputregdelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
      padtoinputregisterdelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
      padtoinputregisterfinedelaysetting : OUT STD_LOGIC;
      readfifomode : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
      readfiforeadclockselect : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
      END COMPONENT;
      COMPONENT cyclonev_io_ibuf
      GENERIC
      bus_hold : STRING := "false";
      differential_mode : STRING := "false";
      simulate_z_as : STRING := "z";
      lpm_type : STRING := "cyclonev_io_ibuf"
      PORT
      dynamicterminationcontrol : IN STD_LOGIC := '0';
      i : IN STD_LOGIC := '0';
      ibar : IN STD_LOGIC := '0';
      o : OUT STD_LOGIC
      END COMPONENT;
      BEGIN
      dataout(0) <= ( wire_sd1_dataout);
      wire_sd1_delayctrlin <= ( wire_ioconfiga_padtoinputregisterdelaysetting(4 DOWNTO 0));
      sd1 : cyclonev_delay_chain
      PORT MAP (
      datain => wire_ibufa_o(0),
      dataout => wire_sd1_dataout,
      delayctrlin => wire_sd1_delayctrlin
      PORT MAP (
      clk => io_config_clk,
      datain => io_config_datain,
      ena => io_config_clkena(0),
      padtoinputregisterdelaysetting => wire_ioconfiga_padtoinputregisterdelaysetting,
      update => io_config_update
      ibufa : cyclonev_io_ibuf
      GENERIC MAP (
      bus_hold => "false",
      differential_mode => "false"
      PORT MAP (
      i => datain(0),
      o => wire_ibufa_o(0)
      END RTL; --IN_delay_buf_iobuf_in_3jr
      --VALID FILE
      LIBRARY ieee;
      ENTITY IN_delay_buf IS
      PORT
      io_config_clk : IN STD_LOGIC ;
      io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
      io_config_datain : IN STD_LOGIC ;
      io_config_update : IN STD_LOGIC ;
      END IN_delay_buf;
      ARCHITECTURE RTL OF in_delay_buf IS
      SIGNAL sub_wire0 : STD_LOGIC_VECTOR (0 DOWNTO 0);
      COMPONENT IN_delay_buf_iobuf_in_3jr
      PORT (
      END COMPONENT;
      BEGIN
      dataout <= sub_wire0(0 DOWNTO 0);
      IN_delay_buf_iobuf_in_3jr_component : IN_delay_buf_iobuf_in_3jr
      PORT MAP (
      datain => datain,
      io_config_clk => io_config_clk,
      io_config_clkena => io_config_clkena,
      io_config_datain => io_config_datain,
      io_config_update => io_config_update,
      dataout => sub_wire0
      END RTL;
      -- CNX file retrieval info
      -- Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone V"
      -- Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
      -- Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
      -- Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone V"
      -- Retrieval info: CONSTANT: enable_bus_hold STRING "FALSE"
      -- Retrieval info: CONSTANT: number_of_channels NUMERIC "1"
      -- Retrieval info: CONSTANT: use_differential_mode STRING "FALSE"
      -- Retrieval info: CONSTANT: use_dynamic_termination_control STRING "FALSE"
      -- Retrieval info: CONSTANT: use_in_dynamic_delay_chain STRING "TRUE"
      -- Retrieval info: USED_PORT: datain 0 0 1 0 INPUT NODEFVAL "datain[0..0]"
      -- Retrieval info: USED_PORT: dataout 0 0 1 0 OUTPUT NODEFVAL "dataout[0..0]"
      -- Retrieval info: USED_PORT: io_config_clk 0 0 0 0 INPUT NODEFVAL "io_config_clk"
      -- Retrieval info: USED_PORT: io_config_clkena 0 0 1 0 INPUT NODEFVAL "io_config_clkena[0..0]"
      -- Retrieval info: USED_PORT: io_config_datain 0 0 0 0 INPUT NODEFVAL "io_config_datain"
      -- Retrieval info: USED_PORT: io_config_update 0 0 0 0 INPUT NODEFVAL "io_config_update"
      -- Retrieval info: CONNECT: @datain 0 0 1 0 datain 0 0 1 0
      -- Retrieval info: CONNECT: @io_config_clk 0 0 0 0 io_config_clk 0 0 0 0
      -- Retrieval info: CONNECT: @io_config_clkena 0 0 1 0 io_config_clkena 0 0 1 0
      -- Retrieval info: CONNECT: @io_config_datain 0 0 0 0 io_config_datain 0 0 0 0
      -- Retrieval info: CONNECT: @io_config_update 0 0 0 0 io_config_update 0 0 0 0
      -- Retrieval info: CONNECT: dataout 0 0 1 0 @dataout 0 0 1 0
      -- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.vhd TRUE
      -- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.inc FALSE
      -- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.cmp TRUE
      -- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.bsf FALSE
      -- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf_inst.vhd FALSE
      -- Retrieval info: LIB_FILE: cyclonev
