About ALTIOBUF simulation
May I know if you are able to share your design file for me to take a look? If yes, I will contact you privately.
Aqid
thanks Aqid, in fact I'm trying to simulate the IOBUF, which is generated by IP catalog, and compilation cannot pass, attached is the generated file, FYI.
-- megafunction wizard: %ALTIOBUF%
-- GENERATION: STANDARD
-- VERSION: WM1.0
-- MODULE: altiobuf_in
-- File Name: IN_delay_buf.vhd
-- Megafunction Name(s):
-- altiobuf_in
-- Simulation Library Files(s):
-- cyclonev
-- THIS IS A WIZARD-GENERATED FILE. DO NOT EDIT THIS FILE!
-- 17.1.0 Build 590 10/25/2017 SJ Standard Edition
--Copyright (C) 2017 Intel Corporation. All rights reserved.
--Your use of Intel Corporation's design tools, logic functions
--and other software and tools, and its AMPP partner logic
--functions, and any output files from any of the foregoing
--(including device programming or simulation files), and any
--associated documentation or information are expressly subject
--to the terms and conditions of the Intel Program License
--Subscription Agreement, the Intel Quartus Prime License Agreement,
--the Intel FPGA IP License Agreement, or other applicable license
--agreement, including, without limitation, that your use is for
--the sole purpose of programming logic devices manufactured by
--Intel and sold by Intel or its authorized distributors. Please
--refer to the applicable agreement for further details.
--altiobuf_in CBX_AUTO_BLACKBOX="ALL" DEVICE_FAMILY="Cyclone V" ENABLE_BUS_HOLD="FALSE" NUMBER_OF_CHANNELS=1 USE_DIFFERENTIAL_MODE="FALSE" USE_DYNAMIC_TERMINATION_CONTROL="FALSE" USE_IN_DYNAMIC_DELAY_CHAIN="TRUE" datain dataout io_config_clk io_config_clkena io_config_datain io_config_update
--VERSION_BEGIN 17.1 cbx_altiobuf_in 2017:10:25:18:06:52:SJ cbx_mgl 2017:10:25:18:08:29:SJ cbx_stratixiii 2017:10:25:18:06:53:SJ cbx_stratixv 2017:10:25:18:06:53:SJ VERSION_END
LIBRARY cyclonev;
USE cyclonev.all;
--synthesis_resources = cyclonev_delay_chain 1 cyclonev_io_config 1 cyclonev_io_ibuf 1
LIBRARY ieee;
USE ieee.std_logic_1164.all;
ENTITY IN_delay_buf_iobuf_in_3jr IS
PORT
datain : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
dataout : OUT STD_LOGIC_VECTOR (0 DOWNTO 0);
io_config_clk : IN STD_LOGIC := '0';
io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0) := (OTHERS => '0');
io_config_datain : IN STD_LOGIC := '0';
io_config_update : IN STD_LOGIC := '0'
END IN_delay_buf_iobuf_in_3jr;
ARCHITECTURE RTL OF IN_delay_buf_iobuf_in_3jr IS
SIGNAL wire_sd1_dataout : STD_LOGIC;
SIGNAL wire_sd1_delayctrlin : STD_LOGIC_VECTOR (4 DOWNTO 0);
SIGNAL wire_ioconfiga_padtoinputregisterdelaysetting : STD_LOGIC_VECTOR (4 DOWNTO 0);
SIGNAL wire_ibufa_o : STD_LOGIC_VECTOR (0 DOWNTO 0);
COMPONENT cyclonev_delay_chain
GENERIC
sim_falling_delay_increment : NATURAL := 10;
sim_intrinsic_falling_delay : NATURAL := 200;
sim_intrinsic_rising_delay : NATURAL := 200;
sim_rising_delay_increment : NATURAL := 10;
lpm_type : STRING := "cyclonev_delay_chain"
PORT
dataout : OUT STD_LOGIC;
delayctrlin : IN STD_LOGIC_VECTOR(4 DOWNTO 0) := (OTHERS => '0')
END COMPONENT;
COMPONENT cyclonev_io_config
GENERIC
enhanced_mode : STRING := "false";
lpm_type : STRING := "cyclonev_io_config"
PORT
dutycycledelaysettings : OUT STD_LOGIC_VECTOR(3 DOWNTO 0);
ena : IN STD_LOGIC := '0';
outputenabledelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
outputfinedelaysetting1 : OUT STD_LOGIC;
outputfinedelaysetting2 : OUT STD_LOGIC;
outputhalfratebypass : OUT STD_LOGIC;
outputonlydelaysetting2 : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
outputonlyfinedelaysetting2 : OUT STD_LOGIC;
outputregdelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
padtoinputregisterdelaysetting : OUT STD_LOGIC_VECTOR(4 DOWNTO 0);
padtoinputregisterfinedelaysetting : OUT STD_LOGIC;
readfifomode : OUT STD_LOGIC_VECTOR(2 DOWNTO 0);
readfiforeadclockselect : OUT STD_LOGIC_VECTOR(1 DOWNTO 0);
END COMPONENT;
COMPONENT cyclonev_io_ibuf
GENERIC
bus_hold : STRING := "false";
differential_mode : STRING := "false";
simulate_z_as : STRING := "z";
lpm_type : STRING := "cyclonev_io_ibuf"
PORT
dynamicterminationcontrol : IN STD_LOGIC := '0';
i : IN STD_LOGIC := '0';
ibar : IN STD_LOGIC := '0';
o : OUT STD_LOGIC
END COMPONENT;
BEGIN
dataout(0) <= ( wire_sd1_dataout);
wire_sd1_delayctrlin <= ( wire_ioconfiga_padtoinputregisterdelaysetting(4 DOWNTO 0));
sd1 : cyclonev_delay_chain
PORT MAP (
datain => wire_ibufa_o(0),
dataout => wire_sd1_dataout,
delayctrlin => wire_sd1_delayctrlin
ioconfiga : cyclonev_io_config
PORT MAP (
clk => io_config_clk,
datain => io_config_datain,
ena => io_config_clkena(0),
padtoinputregisterdelaysetting => wire_ioconfiga_padtoinputregisterdelaysetting,
update => io_config_update
ibufa : cyclonev_io_ibuf
GENERIC MAP (
bus_hold => "false",
differential_mode => "false"
PORT MAP (
i => datain(0),
o => wire_ibufa_o(0)
END RTL; --IN_delay_buf_iobuf_in_3jr
--VALID FILE
LIBRARY ieee;
ENTITY IN_delay_buf IS
PORT
io_config_clk : IN STD_LOGIC ;
io_config_clkena : IN STD_LOGIC_VECTOR (0 DOWNTO 0);
io_config_datain : IN STD_LOGIC ;
io_config_update : IN STD_LOGIC ;
END IN_delay_buf;
ARCHITECTURE RTL OF in_delay_buf IS
SIGNAL sub_wire0 : STD_LOGIC_VECTOR (0 DOWNTO 0);
COMPONENT IN_delay_buf_iobuf_in_3jr
PORT (
END COMPONENT;
BEGIN
dataout <= sub_wire0(0 DOWNTO 0);
IN_delay_buf_iobuf_in_3jr_component : IN_delay_buf_iobuf_in_3jr
PORT MAP (
datain => datain,
io_config_clk => io_config_clk,
io_config_clkena => io_config_clkena,
io_config_datain => io_config_datain,
io_config_update => io_config_update,
dataout => sub_wire0
END RTL;
-- CNX file retrieval info
-- Retrieval info: PRIVATE: INTENDED_DEVICE_FAMILY STRING "Cyclone V"
-- Retrieval info: PRIVATE: SYNTH_WRAPPER_GEN_POSTFIX STRING "0"
-- Retrieval info: LIBRARY: altera_mf altera_mf.altera_mf_components.all
-- Retrieval info: CONSTANT: INTENDED_DEVICE_FAMILY STRING "Cyclone V"
-- Retrieval info: CONSTANT: enable_bus_hold STRING "FALSE"
-- Retrieval info: CONSTANT: number_of_channels NUMERIC "1"
-- Retrieval info: CONSTANT: use_differential_mode STRING "FALSE"
-- Retrieval info: CONSTANT: use_dynamic_termination_control STRING "FALSE"
-- Retrieval info: CONSTANT: use_in_dynamic_delay_chain STRING "TRUE"
-- Retrieval info: USED_PORT: datain 0 0 1 0 INPUT NODEFVAL "datain[0..0]"
-- Retrieval info: USED_PORT: dataout 0 0 1 0 OUTPUT NODEFVAL "dataout[0..0]"
-- Retrieval info: USED_PORT: io_config_clk 0 0 0 0 INPUT NODEFVAL "io_config_clk"
-- Retrieval info: USED_PORT: io_config_clkena 0 0 1 0 INPUT NODEFVAL "io_config_clkena[0..0]"
-- Retrieval info: USED_PORT: io_config_datain 0 0 0 0 INPUT NODEFVAL "io_config_datain"
-- Retrieval info: USED_PORT: io_config_update 0 0 0 0 INPUT NODEFVAL "io_config_update"
-- Retrieval info: CONNECT: @datain 0 0 1 0 datain 0 0 1 0
-- Retrieval info: CONNECT: @io_config_clk 0 0 0 0 io_config_clk 0 0 0 0
-- Retrieval info: CONNECT: @io_config_clkena 0 0 1 0 io_config_clkena 0 0 1 0
-- Retrieval info: CONNECT: @io_config_datain 0 0 0 0 io_config_datain 0 0 0 0
-- Retrieval info: CONNECT: @io_config_update 0 0 0 0 io_config_update 0 0 0 0
-- Retrieval info: CONNECT: dataout 0 0 1 0 @dataout 0 0 1 0
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.vhd TRUE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.inc FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.cmp TRUE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf.bsf FALSE
-- Retrieval info: GEN_FILE: TYPE_NORMAL IN_delay_buf_inst.vhd FALSE
-- Retrieval info: LIB_FILE: cyclonev
- AqidAyman_Altera2 months ago
I have contacted you in private. Can you check your inbox?
