A10 DDR4 fails calibration
Hi Sir,
You interface is 800MHz with one CS. By right, this speed do not need to turn on board deskew.
I am also curious about the debug results, which says that calibration failed on write deskew; does this mean that everything before write deskew (address/cmd leveling, address/cmd deskew, read deskew, etc.) passed?
Answer: Not necessary. Sometime, the previous calibration will create some flaw and cause current stage unable to calibration successful. And this time, I will suggest you to give this a try - https://www.intel.com/content/altera-www/global/en_us/index/support/support-resources/knowledge-base/solutions/fb292783.html
Try turn on both of the option as below:
Skip address/command leveling calibration
Skip address/command deskew calibration
Aida
