Spectrum
5 years agoA Substitute/Replacement CPLD p/n 5M40ZE64C5N ???
Intel/Altera CPLD part number 5M40ZE64C5N, I need quantity 210 ASAP for production units.
The lead time on this and other similar CPLDs have a long lead time.
Are you able to suggest a similar ...
ak6dn
4 years agoEasy.
Speed grade 4 is faster than speed grade 5.
C range temp is narrower than I range temp.
So a C4 timing spec device over 0'C to 85'C can also meet I5 timing spec over -40'C to 100'C.
So a dual marked C4/I5 device is certainly possible.
GD500
4 years agoYeah, I figured it out a little later on. I had the 4 and 5 speeds backwards. The brain wanted to believe the 5 was faster.
