16 years agoA question about Altera
Let's say i have a signal and i want this signal to take different values every clock time.How can i define these values?.For example i want for the first clock cycle the value of the signal to be 15, on the second 35 etc.My clock cycle is 15ns.So i try to use arbitary value option but when i try to insert the second value(from 16 to 30ns ) it overwrites the first cycle value.
Thanks in advance3 Replies
Thanks for the reply.And yes my problem is to define values in the simulator.Ok i found the solution.It is a bit of time consuming but it is ok.Thanks again
Tricky,
I think his problem is in defining values for the Quartus Simulator. triggerman, I think you can select just 15 ns of the signal, then set the value for those 15ns. - Altera_Forum
use a look up table.
