19 years ago93% usage, ripple clocks warning
The outputs are doing what I want them to, but I'm getting warnings about ripple clocks, etc. The compiler says 93% usage (60/64 cells). Would like to stick with the lower cost 44 pin devi...
19 years agoIt sounds more like a warning for the way you solved your task. You could read -> Quartus II Handbook Volume 1: Design and Synthesis -> Section II. Design Guidelines -> Chapter 5. Design Recommendations for Altera Devices and the Quartus II Design Assistant (especially "Design Guidelines") and maybe there is a usefull suggestion which would fix the warning.
