19 years ago91c111 ethernet hangs
I seem to have a problem with the ethernet driver hanging during board boot up and initialization. I've got a Stratix II interfacing to an SMSC 91c111 ethernet chip in what is similar to a VESA stan...
19 years agoIt can occur either because of DHCP or because of Auto-negotiation process.
It is possible to try to remove DHCP in IP stack settings. In old versions (6.0 or early) it was necessary to correct a code of phy initialization of 91c111. During Auto-negotiation at not connected cable it came to the end on timeout and the critical error was caused.
