16 years ago8b10b clock recovery?
Would it be possible to use an Altera FPGA (Arria II GX or Cyclone IV GX) to snoop on a 2.5 Gbps PCI Express link (via the PIPE interface), recover the clock and send out the recovered clock to one o...
16 years ago --- Quote Start --- My initial though was to clock the scope with one of the signals in the differential pair. This, of course, means that jitter will not be measurable since the scope will always trigger on the rising (or falling) edge of the signal, effectively not displaying the jitter. --- Quote End --- I need to correct myself. Jitter is defined as variations in the high or low bit times and due to this, the jitter will be visible as variations in the signal transitions in the right part of the eye diagram. Therefore, it should be fine to trigger the scope on one of the differential signals. It will not be accordingly to the PCIe spec's compliance rules but it will be useful as a comparison tool to find out whether signal degradation occurs in my setup.
