16 years ago7064BLC44-7 problem with pin setup in Quartus
Hello, I'm trying to import old Max+ project into quartys 5.1. This is for device 7064BLC44-7. Quartus doesn't have this device on the list, the closest I can get is 7064BTC44-7. But when I tr...
16 years agoIt seems that the 7064BLC44 is the forgotten device :-)
7064BLC is the plcc version and 7064BTC the tqfp if you compare both pinouts you will see that they differ where they start to count the pins 7064TLC44 pin 1 is 7064BLC44 pin 7 7064TLC44 pin 2 is 7064BLC44 pin 8 Quartus knows the EPM764AELC44-7 but i am quit unshure if you can compile for this device and run it on your target. you could give it a try and / or ask mysupport or your fae or hopefully somebody else knows a solution
