Mike-PSEG
1 year ago68 pin FPGA
Is there a device I can use to replace a few Altera EP1800 devices with the same pin out? Thanks, Mike
- 1 year ago
There is no pin to pin replacement for Altera EP1800. You may need to consider to use the latest device.
Aiman
FvM
1 year agoHi,
your are asking for a 5V programmable logic device. There are very few devices still available these days, e.g. Atmel/Microchip ATF15 series. ATF1508AS in TQFP100 would fit an SMT adapter board that can be soldered or plugged to EP1800 PLCC68 footprint.
Mike-PSEG
1 year agoThanks for that information.
I know this is a tough problem. I'm trying to support older equipment that uses the Altera EP1800.
I'll look into the ATF device.
I appreciate your help!!
Mike
