5M1270ZT144A5N in place of 5M1270ZT144C5N
We are thinking of using 5M1270ZT144A5N in place of 5M1270ZT144C5N; Can we do it without board redesign? Will there be a significant impact if we replace 5M1270ZT144C5N with 5M1270ZT144A5N?
Also, what is UFM & CFM values for 5M1270ZT144A5N, we could not find these details in spec sheet.
- Ash_R_Altera
We do not receive any response from you to the previous answer that I have provided. This thread will be transitioned to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you
- Ash_R_Altera
The difference between 5M1270ZT144A5N and 5M1270ZT144C5N is only the temperature grade. The A device is Automotive grade (-40 to 125 deg C) whereas the C device is commercial grade (0 to 85 deg C).
Both the devices are fully compatible to each other and do not require any board changes for replacement.
I did not understand your query related to "values of CFM and UFM". Are you asking how to read the content of flash memory? If yes, then use the stand-alone embedded Jam STAPL Player and Jam Byte-Code Player provide action commands for programming or reading the entire flash memory (UFM and CFM together) or each independently.
For more details please refer the MAX V Device Handbook, section 7.
