11 years ago5CEFA5F23 Power-up and JTAG problem
JTAG can not find the device, so I check the nSTATUS and CONFIG_DONE signal.
It's weird that nSTATUS and CONFIG_DONE signal are high before I configure the device. The board is a new one and the flash is empty, why CONFIG_DONE signal high before I configure the device ? There are some other problems about this board, as follows, 1, Power-up sequence is not the same as datasheet. 2, Power-rail has some noise. But I think maybe they are not the problem, there maybe some problem else. Thank youNo RepliesBe the first to reply
