ShivaKi
2 years ago5CEBA7F27C8N FPGA IO Pin Status After Power ON Reset
Hello, For FPGA 5CEBA7F27C8N, 1. What will be the status of IO Pins after Power ON Reset, when IO pins are configured as a. Input b.Output c. Input/Output 2. What will be the stat...
AqidAyman_Altera
2 years agoHello,
- After Power On Reset (POR), all the I/Os pins are tied to an internal weak pull-up before entering the user mode.
- After functional reset, the I/O pins will behave following the logic you assigned in your code. It is dependent on the design itself.
Aqid
