10 years ago5 Gbps USB 3.0 PIPE interface via Cyclone V GT 6 Gbps transceivers?
I'm considering using a Cyclone V GT (that has 6 Gbps transceivers) to implement a USB 3.0 protocol analyzer. The idea is to split the upstream and down stream signals (externally) and input a copy o...
9 years agoHi John,
you should contact Altera support on that, if it is possible they should be able to give you a solution. Cheers, fade
