19 years ago5.0V Devices ?
Hi, I'm trying to drive a 5-volt device , ie CD-Rom drive, with my Cyclone board and was wondering if it's possible at all? Or does Cyclone only suppport 3.3V at its output pins. Would it work ...
19 years agoYou can use bidirectional level translators or FET switches to protect the cyclone device from 5V supply. By using +3.3V LVTTL or LVCMOS standard, you can meet the minimum input requirements (VIH) of +5V standard (which is usually around 2.4V). By using level translator or FET switch, you can protect cyclone device against pure +5V output from your target device.
Hope this will help. Regards, BD
