MSmit101's avatar
MSmit101
6 years ago
4*6 bits register does not retain it's value EPM7064
Hi all,
I have something very strange happening. I have programmed a Altera 7000 Series EPM7064 device. In it I created 4*6 bits register. Simulation is all good. Reset, writing and reading is all good.
Only in real life, checked with my Logic Analyser, I see the write but a microsecond later the value of the register does not appear on the output pins. Instead only zeroes appear.
Here the output of the simulator:
At the bottom is the input data, all 3 lower bits high. In the middle the output of the register is written because WR and EN is low. And after writing it stays visible on the output pins [2][1][0].
Here the output of the programmed device with the logic analyser:
The data D5/D6/D7 briefly appears at D2/D3/D4 and then goes back to zero and it stays that way.
Here the Verilog code:
module scc_rom_mapper (wr_n,sltsl_n,reset_n,a15_a13_a12,data,address_upper);
input [2:0] a15_a13_a12;
input [5:0] data;
input wr_n,sltsl_n,reset_n;
output reg [5:0] address_upper = 0;
// 4*6 bits storage
reg [5:0] mem0 = 6'b000000;
reg [5:0] mem1 = 6'b000001;
reg [5:0] mem2 = 6'b000010;
reg [5:0] mem3 = 6'b000011;
wire WE;
assign WE = !reset_n || (!sltsl_n && !wr_n);
// write memory
always @(posedge WE) begin
if (!reset_n) begin
mem0 <= 6'b000000;
mem1 <= 6'b000001;
mem2 <= 6'b000010;
mem3 <= 6'b000011;
end
if (!sltsl_n) begin
// store only when upper 4k is selected
case(a15_a13_a12)
3'b001: mem0 <= data;
3'b011: mem1 <= data;
3'b101: mem2 <= data;
3'b111: mem3 <= data;
default: ;
endcase
end
end
// read memory
always @(*) begin
// always select correct bank when reading or writing
case(a15_a13_a12[2:1])
2'b00: address_upper <= mem0;
2'b01: address_upper <= mem1;
2'b10: address_upper <= mem2;
2'b11: address_upper <= mem3;
endcase
end
endmodule
  • sstrell's avatar
    sstrell
    It's not clear which signals are which in your simulation or your scope picture. Can you clarify?
    And your coding for the "clock", WE, is strange. Do sltsl_n or wr_n toggle high/low for a write?
    Also, you need an "else" on your check of sltsl_n in order to correctly code a register:
    if (!reset_n) begin
    else if (!sltsl_n)
    Finally, it might be cleaner to code a 4x6 array instead of separate registers like this:
    reg [5:0] mem [0:3];
    #iwork4intel
    • MSmit101's avatar
      MSmit101
      In my design for an old retro computer project. I allow WRite when the SLot is SELected. I tried earlier an always (*) block with if/else statements but this wouldn't work. Hence the "clock" type of setup.
      BTW. I did solve the issue at hand, being that the address_upper lines are cleared and not showing mem.
      Somehow the reg[x] mem [x] initialisation was done at every evaluation. After putting this in an initial begin/end block this was solved.
      So problem gone. ;-)
  • SyafieqS's avatar
    SyafieqS
    Hi Mario,
    What I understand the control signal in your case is sltsl_n(sel) and wr_n(wr) should be toggling. The register is written when sltsl_n and wr_n is high on same clock edge. It return the current data when sltsl_n is high and wr_n is low. Using if else statement for this process as shown below is snippet sample.
    always @ (posedge clk) begin
    if (!rstn)
    register <= 0;
    else begin
    if (sel & wr) // when both signal is high
    register <= wdata; // non-blocking statement wdata assigned to register
    else
    register <= register;
    end
    end
