12 years ago40 pin gpio connector
hello how i can use the 40 pin gpio of a de2 cyclone 4 as an input and output? can it be added in qsys? thanks
12 years agoI think you're getting confused as to what to use to do what you want.
If you want to develop C code, in Eclipse, I recommend you use the standard PIO peripheral - where we started with this thread. You can then develop your application entirely in C code, within the Eclipse environment. This way there would be no need for any custom rtl. The rtl you posted could be used (subject to it working, I've not checked it ;)) if you want to capture the keystrokes in hardware - a commendable way of solving this. However, if you then wish to use this code as a Nios peripheral then you will need to add an appropriate interface to that code. Or, you could use your rtl to drive a PIO peripheral set as 4-bit, input only, driven by the 'keyboard_val' signal from your rtl. Rhetorical question: What are you most comfortable coding? If you're happy writing rtl do it that way, minimisung the amount of C code you have to write. If you prefer writing C, use qsys/systembuilder to implement the logic and write the solution in C, within Eclipse. Regards, Alex
