4-8 Channel ADC for Altera DE2-115 using Simultaneous Sampling
We are building an Educational Embedded Computing System for a Road Profiler. I am incharge of taking care of the ADC interface to the DE2-115 board. Can anyone please suggest a suitable 16-bit standalone ADC which has on-chip flash memory, 4-8 Channels, Minimum Sampling Rate 1Mhz, Simultaneous Sampling Possible with all channels active and acquiring data, and that can be interfaced to the DE2-115 board using any protocol say I2C or using the HSMC interface?
There are cards available by Terasic, but they only have a 2 Channel 14-bit ADCs which can be interfaced to the HSMC connector. Also, we will be connecting a laser through the Ethernet Connector on the board and processing data. Is it possible to have Parallel Processing of the Data where all the data from the 4 Channels on the ADC and the data from the Laser can be simultaneously processed? We are completely new to the FPGA, including my professor. Hence we are all faced with tough challenges. Can somebody please help me out ASAP!!!13 Replies
--- Quote Start --- I have valuable data coming in from an accelerometer. So this data needs to be sampled to at least a 16-bit resolution. Considering the sampling rate that I require, which is definitely less than 250khz, I guess this can be better than LTC1470. --- Quote End --- Ok, so you have two important pieces of information here; you require 16-bits of dynamic range over a bandwidth of less than 125kHz (Nyquist bandwidth for sampling at 250kHz). If the signal-to-noise (SNR) of the signal you are sampling is dominated by quantization noise, then you can oversample the signal, then digitally filter and decimate the signal. For every oversampling factor of 4, you gain about 1-bit in SNR, so to achieve 2-bits of SNR you need to oversample by 16x, i.e., 16 x 250kHz = 4MHz. Don't the Terasic ADC boards operate at close to 100MHz? I think you should try to look for an existing ADC board that can meet your requirements before trying to attempt to build your own. For example, what does the signal you want actually look like? Go and use an oscilloscope or an ADC board and capture a few MB of data, then Fourier transform that data to look at its spectral response. How much dynamic range do you really have, is it 16-bits? Cheers, Dave - Altera_Forum
Thanks a lot for the valuable information James. This looks to be a good part, but it still is 14-bits.
I have valuable data coming in from an accelerometer. So this data needs to be sampled to at least a 16-bit resolution. So for a 16-bit, I tried to look this one up: I tried to look up LTC1865 . Considering the sampling rate that I require, which is definitely less than 250khz, I guess this can be better than LTC1470. I have looked up these too, TI has the ADS8556 , which is good Analog Devices has AD7606-6 But I havent worked with the Verilog/VHDL before much, just simple gate/logic/mux designing and am completely new to the NIOSII, so I do not know how I am going to interface this to the FPGA. I definitely know the SPI and I2C buses, but then, what about the driver for these ADCs and their initialization? I appreciate your consideration in helping me out for the VHDL driver, which I must say will be extremely valuable to me, since I am a complete beginner at everything. Wont the specific ADCs be required to be initialized using their specific firmware from the Manufacturer? Also, I will have to design a board myself for interfacing this as a peripheral through the GP I/O lines on the DE2-115 board, right? Because this just comes in as a chip and I will have to put it on a GP board and come up with the Pull Ups and the Noise Cancelling Caps etc? Excuse me for being to naive and asking stupid questions, but I am a complete beginner and have been assigned this task, which although doesn't have a deadline, needs to be completed at a satisfactory pace, since this is applied research for professor that I work for, and he hasn't worked on FPGAs ever before. Hope you can help me more. Thanks a lot again!! :) - Altera_Forum
I have used the LTC1407A-1 from Linear Tech and interfaced it to Cyclone III and Cyclone IV many times on various boards I've designed over the years. They also make a LTC1407A, which is a unipolar part, while the LTC1407A-1 is a bipolar type part.
You just need SCLK, CONV, and SDO for each ADC. Each ADC Simultaneously samples two channels at 1.5 MSPS. This is an excellent part, I have had good experience with it. I'd be happy to help you with the VHDL driver.:) James
