14 years ago4-8 Channel ADC for Altera DE2-115 using Simultaneous Sampling
We are building an Educational Embedded Computing System for a Road Profiler. I am incharge of taking care of the ADC interface to the DE2-115 board. Can anyone please suggest a suitable 16-bit stand...
14 years ago@Dave:
Thanks a lot. Yes, Terasic boards operate at very fast speeds. I am not trying to construct my own board for the time being. My professor too told me to look into existing boards and buy one out. I will test the signal that you are talking to me about and check its spectral response and see if I actually need a range of 16 bits. If not necessary, then I can definitely go for ADCs which are more accurate or I can go by your idea of oversampling the signal for a better SNR. Thank you Sir again for your valuable information. @James: I havent used either much, this is after 2 years that I am even getting back to Verilog programming. I appreciate all your help and advice. I will however be selecting the correct ADC and will soon begin work with it and keep in mind your advice about the the testing and design. Also, I might ask really lame and stupid questions or ask for help from time to time. Hope you dont mind helping me out. Thanks a ton Sir! Yash
