15 years ago3 NODES IN JTAGCONFIG -n SHOWN . How to delete one?
Hello, I'm doing altera tutorial project "hello word small" FPGA is CycloneIII 3C25 Software Quartus II 10.1sp1 Web Edition NIOSII EDS 10.1 sp1 Cable USB-Blaster SOPC ...
15 years agoI'm not sure...check clock, reset, memory interfaces, etc. For a first program, I would try creating something very small that will fit in a small (16K or less) onchip memory. No offchip memory...to start with.
Also, when you do a "jtagconfig -n" with the E core, do you see only two nodes? If Nios II/s or f were the cause of the OCP, then that should be the case. Regards, slacker
