16 years ago2v5 Epcs
We have been using the ST Micro M25P16 as EPCS device for 3V3 designs. Is there a 2V5 equivalent flash chip or alternative? Thanks. The only relevant info I have found is Altera AN 523: Cyclo...
16 years agoPX devices are said to support 50 MHz down to 2.3 V, but they are not fully compatible to EPCS respectively M25Pnn devices, e.g. missing the electronic signature expected by the Quartus programmer. There may be ways to use it as AS configuaration memory though. I have no urgent need for 2.5V AS devices now, however. I simply stay with 3.3V operation for part of the IO banks.
P.S.: As Altera is permanently emphasizing the problems of 3.3V VCCIO with 65 nm devices, they should be more motivated to find a suitable solution for 2.5V AS configuration, I think.
