14 years ago2 Serial Devices on one board
Hello all,
I am currently working on a project in which I need to connect two digital sensors, a Temp & Humidity sensor(SHT 15) and an accelerometer (ADXL345) both digital sensors. They also both use serial communications, and I'm not sure how to connect both of them to the board to be able to have them both run. My ideology is to have one run through the RS232 port... and the other ??? Create a serial connection through the Expansion Headers? Is this even possible? The simplest solution would be best, because I'm sure as you can see by reading, I am a beginner. Thanks PS I'm using the DE2 Development board10 Replies
Or if you plan to use bit banging, all you need on the hardware side is a 2 port PIO. - Altera_Forum
--- Quote Start --- My real question lies in the implementation of I2C protocol. I don't see a core for I2C implementation.. any advice? OpenCores.org? --- Quote End --- The DE0-nano examples provided by Terasic use bit-banging to implement the I2C protocol. If you're going to use a NIOS II core, then that would be my recommendation. I believe others have used the OpenCore's I2C core. Search the archive. Cheers, Dave - Altera_Forum
Ok, we have invested in a new SHT21 which uses I2C.
Now when building our system in SOPC builder, I have added a SPI(3-wire interface) for the ADXL345 under Interface Protocols->Serial->SPI(3 wire interface). Setup: Type-Master Number of Selects-1 SCLK-4900000 Data width- 32 bits Shift- MSB Clock Polarity and Phase-0 My real question lies in the implementation of I2C protocol. I don't see a core for I2C implementation.. any advice? OpenCores.org? - Altera_Forum
--- Quote Start --- So from what I have gathered from everyone's responses is that the ADXL345 is going to work well since I can connect to the SPI/I2C Core on the board using the expansion headers. The SHT15 however, is not so nice since it will require me writing its own protocol in Verilog(I Assume?) ... --- Quote End --- Yep, you've got it. --- Quote Start --- Sorry if this seems basic, but in our class we only scratched the surface of using the SPI and we were supposed to write our own protocol but the teacher scrapped that due to us falling behind. --- Quote End --- Since you are not familiar with programming in HDL, then you probably want to find another sensor that has an I2C or SPI interface. Cheers, Dave - Altera_Forum
--- Quote Start --- The SHT15 sensor uses a non-standard serial protocol, which uses a serial clock and bidirectional serial data --- Quote End --- Oh yes sorry about that, the SHT15 doesn't use standard I2C. We are actually using a SHT2x in one of our projects, which does use I2C, and I just assumed the STH1x were the same. You are write, you will have to write a custom component to access it, or as dave says use bit banged i/o, with PIOs for example. If you really need the humidity you can try the SHT20 instead, that uses a I2C bus. If you only need temperature there are lots of other I2C sensors, such as the FM75. - Altera_Forum
The SHT15 however, is not so nice since it will require me writing its own protocol in Verilog(I Assume?) ... Sorry if this seems basic, but in our class we only scratched the surface of using the SPI and we were supposed to write our own protocol but the teacher scrapped that due to us falling behind. Are the questions I'm asking clear? Should I just find another temp and humidity sensor to better work with the board, or that uses the standard protocol? - Altera_Forum
I didn't get a chance to look at the data sheets yesterday ... your comment about RS232 threw me off on the wrong track ... --- Quote Start --- I am currently working on a project in which I need to connect two digital sensors, a Temp & Humidity sensor(SHT 15) and an accelerometer (ADXL345) both digital sensors. They also both use serial communications --- Quote End --- The ADXL345 can be accessed via either SPI or I2C, so the device can be connected directly to pins on the expansion header. The DE0-nano contains the ADXL345 device, so there should be examples you can use with that board. The SHT15 sensor http://www.sparkfun.com/datasheets/sensors/sht1x_datasheet.pdf uses a non-standard serial protocol, which uses a serial clock and bidirectional serial data, where the data signal should only ever be driven low to avoid driver conflict. You will have to create a custom interface to this device, I'd recommend starting with bit-banged I/O, where the clock signal is driven as an output and the data controls the enable on a tri-state buffer that will drive low when enabled. Both of these devices can be interfaced directly to your FPGA pins. You would not use an RS232 level translator. Try coding up an interface, and if you have trouble, ask questions here on the forum. Cheers, Dave - Altera_Forum
IIRC RS232 should be +12v/-12v negative logic (-12v is a logic 1), however a lot of modern systems only drive a much lower range, possibly even +5v/0v!
However the receivers have to allow for the full voltage range. - Altera_Forum
IIRC the SHT sensor uses an I2C bus, which is another serial protocol. You will need some external pull-ups (or maybe use the FPGA's internal ones) and find a bus controller IP. There is one available on opencores (http://opencores.org).
Read the data sheet for the sensors carefully.
Since you are a beginner, I will provide a little bit of terminology; 1. UART Universal Asynchronous Receiver/Transmitter. Also known as a serial port. 2. RS232 Level-shifted (and inverted) UART transmit and receive signals. If your sensor data sheet states that the signals are logic level, eg., 3.3V signals, then the signals are the output of a UART. If the data sheet states that the signals are RS232, then they are level shifted, and will probably be +/-10V signals. Measure the signals with an oscilloscope and see. If the signals are UART logic levels, then you can instantiate a pair of UARTs in the FPGA and control the sensors directly. If the signals are RS232 levels, then you need a level translator, i.e., an RS232 level to logic level translator. The DE2 has a serial port - check the schematic and see if there are enough level translators on the DB9 for either one or both sensors. Sparkfun and other microcontroller online stores will have cheap boards with RS232 level translators and 100-mil header connectors that you can use. Cheers, Dave
