14 years ago2 Serial Devices on one board
Hello all, I am currently working on a project in which I need to connect two digital sensors, a Temp & Humidity sensor(SHT 15) and an accelerometer (ADXL345) both digital sensors. They also bo...
14 years ago --- Quote Start --- The SHT15 sensor uses a non-standard serial protocol, which uses a serial clock and bidirectional serial data --- Quote End --- Oh yes sorry about that, the SHT15 doesn't use standard I2C. We are actually using a SHT2x in one of our projects, which does use I2C, and I just assumed the STH1x were the same. You are write, you will have to write a custom component to access it, or as dave says use bit banged i/o, with PIOs for example. If you really need the humidity you can try the SHT20 instead, that uses a I2C bus. If you only need temperature there are lots of other I2C sensors, such as the FM75.
