14 years ago2.5V AS serial configuration device?
I'm finising off a spin of a board and trying to move from VCCIO of 3.3V to 2.5V. We're pin constrained so I'm moving the banks with the configuration pins too. I'm using active serial config a...
14 years agoWhat if you use this spansion part:
S25FL128P0XNF http://www.spansion.com/support/datasheets/s25fl128p_00.pdf And run it at 2.7V. The IOs on the FPGA should be able to talk to it.
