12 years ago15fps to 60fps video conversion
I believe somebody had similar problem, but I simply cannot find it. I want to display my 15fps 1920x1080 video @33MHz on HDTV monitor accepting 60fps framerate, running at approximately @133M...
12 years agoThank you for your effort Ted! It is highly appreciated.
Unfortunately, I cannot lower the Test Pattern Generator frequency, since Frame Buffer requests the same clock on writer and reader sides. There is no parameter for the TPG's framerate, it fires all the time at the Avalon-ST clock rate.
