12 years ago15fps to 60fps video conversion
I believe somebody had similar problem, but I simply cannot find it. I want to display my 15fps 1920x1080 video @33MHz on HDTV monitor accepting 60fps framerate, running at approximately @133M...
12 years ago --- Quote Start --- In the user guide for the board, it states that the on-board SDRAM maximum frequency is approximately 125MHz. --- Quote End --- Please check that point again. I believe you are reading the SRAM description. --- Quote Start --- It is a Cyclone IVE board, with two IS42S16320B-7TL SDRAM modules connected in parallel so the effective data width is 32 bits. Datasheet for the component states the maximum frequency is 143MHz. --- Quote End --- Well, at least you've got 10MHz more available should you choose to pursue it. --- Quote Start --- I see no progress with these. --- Quote End --- You're going to have to investigate further; theres a chance you still have an inefficient configuration of the SDRAM / Avalon-MM which might clear things up for you. And if push came to shove, I believe you can also get away with disabling SDRAM refreshes. But before pursuing that with any substantial effort, I would first confirm the problem using SignalTap to watch it happen and possibly decreasing the Clocked Video Output rate until you identify a working configuration, so you can get an idea of exactly how far away you are from your goal.
