12 years ago15fps to 60fps video conversion
I believe somebody had similar problem, but I simply cannot find it. I want to display my 15fps 1920x1080 video @33MHz on HDTV monitor accepting 60fps framerate, running at approximately @133M...
12 years agoThank you for the reply.
In the user guide for the board, it states that the on-board SDRAM maximum frequency is approximately 125MHz. It is a Cyclone IVE board, with two IS42S16320B-7TL SDRAM modules connected in parallel so the effective data width is 32 bits. Datasheet for the component states the maximum frequency is 143MHz. Referring to your advices: - now the entire system runs on 133MHz, with SDRAM clock being phase shifted for -65 degrees. - Frame Buffer Avalon-MM master port matches the SDRAM port width, being 32. - I increased both the Frame Buffer burst target and FIFO depth to maximum values available in the GUI - I increased the Clocked Video Output embedded FIFO depth to be twice a line length (app 4k) I see no progress with these.
