14 years ago148-pin QFN case on 1 mm PCB
Hello, In its Cyclone 4 family Altera introduced new 148-pin QFN case. What is the reason to recommend rather thin PCB, <0.8 mm, for this case? Is it PCB thermal expansion? And what ca...
14 years agoThe knowledge base explanation isn't particularly clear. But there's no other thinkable reason than thermal expansion in my opinion. It's your decision if you follow the Altera suggestion or ignore it. I think, there's a lot of chip packages that are exposed to similar specific solder joint forces due to thermal expansion.
