9 years ago125 MHz clock+data output
I have a design with a CycloneIV that needs to talk to a GMII PHY, which expects data bytes on 8 parallel lines along with a clock signal. I use a PLL to generate a 125 MHz clock, and would now...
9 years agoHave you looked at this guide: https://www.altera.com/en_us/pdfs/literature/ug/ug_altddio.pdf on using the DDR I/O macro functions?
