akohlsmith
7 years ago10M08DAF256 - LVDS rx-only, can IO bank be at 3.3V?
Subject says it all; I have a 10M08D and I have accidentally connected bank 5 and 6 to my 3.3V supply and not a 2.5V supply as is specified for LVDS I/O. I am not sure how this managed to get past th...
SreekumarR_G_Intel
7 years agoThank you giving opportunity to look at issue,
Can I assume few things from your input ,
i) You are not plan to use LVDS in the board using FPGA. Correct ?
ii) The VCCIO of bank 5 and 6 connected to the 3.3V. Also Can I assume VREFBx pin is not used for reference voltage ? Correct
If my above assumption yes , I don’t think so there is issue to connect the 3.3V bank 5 and bank 6 .
In the datasheet can you refer page 7 for the max apply VCCIO ?
Note : VCCA must connected to the 2.5V.
May I know why you think bank 5 and 6 need to use only for LVDS ?
Thank you,
Sree
