10M02SCM153C8G POWER USE
- 2 years ago
Recommend you to follow the guidelines provided for the device on following page:
Notes to the Intel® MAX® 10 FPGA Pin Connection Guidelines
The above link mainly recommends placement of the capacitors, but eventually user should be doing the board level simulations to check signal integrity of the board.
As you rightly said, the power consumption depends a lot on the design. For the power consumption estimation use the Early Power Estimator tool:
MAX 10 PowerPlay Early Power Estimator (EPE) | Intel
