14 years ago10G Ethernet and 10G Base-R PHY Hardware Demonstration Design
Hi all, I am trying to test board-to-board communication using a complete 10G Ethernet design that includes an Altera 10 GbE MAC + an Altera 10GBASE-R IP cores. My devices are Stratix IV GT and...
14 years agoThanks Dave for your quick answer.
--- Quote Start --- When you access each board, are you making sure to open the correct device? SystemConsole 'get service paths master' will return the path to both boards. Do you select one entry for the transmitter and the other for the receiver? How do you know which is which? Hint: in the system design, make the DIP switches readable, and set them differently on each board :) --- Quote End --- I am not sure if I fully understood your point. As I understand, System Console command "get_service_paths master" will return a list of master services connected to the host PC. And because I use two different PCs, each connected to a board separately. So, each System Console gets the path to each board, and I don't have to select service for transmitter and receiver after command "get_service_paths master". Am I wrong here? --- Quote Start --- Since the system is being accessed using SystemConsole, its most likely implemented using SOPC Builder or Qsys. Open the system design with the appropriate tool and you will see the address map defined there. --- Quote End --- The design is composed of one Qsys based system (10Gbps MAC+ 10GBASE-R), one Traffic controller (in verilog) and one System controller (in verilog). I opened the Qsys system to see the base addresses of the MAC and the PHY but there are not. The base addresses should be assigned somewhere else. Usually, where people assign base address for a HDL-based component like Traffic controller? Thanks
