14 years ago10G Ethernet and 10G Base-R PHY Hardware Demonstration Design
Hi all, I am trying to test board-to-board communication using a complete 10G Ethernet design that includes an Altera 10 GbE MAC + an Altera 10GBASE-R IP cores. My devices are Stratix IV GT and...
14 years ago --- Quote Start --- My next plan is to test board-to-board communication with the two boards rather than looping back on the same board using the provided TCL scripts. As I am new to such task and there are a lot to grasp, I wonder where I should start to realize my purpose. --- Quote End --- You can probably run exactly the same design on both boards, and just connect them together. Try it and see what happens. If nothing works, then read the Tcl scripts and see what they are doing. Your current question is a little vague. Most people will not have your hardware setup, so cannot duplicate your system. So just start using the hardware and see how far you get. If you cannot understand what a particular SystemConsole Tcl sequence is doing, then you can ask specific questions, and you'll be more likely to get answers. Cheers, Dave
