suvarna
1 month ago10CL040YF484 Programming fails
1st Vendor Batch (Date Code: 2525): - First Test (3 FPGAs): - Card 1: ISP and JTAG programming successful; functioning correctly. - Card 2: Programmed in ISP mode, ...
suvarna
1 month agoDear Sir,
please see my previous mail attached schematic and please see images attached . in working card DEVICE ID is coming and in bad card direct its telling JTAG error.
please see the attached images
VCCIO bank1 voltage is 3.3V only and VREF pins i am using them as i/o pins.
MSEL setting "0010" and nCE grounded with 10k resistor and connected to programmer 6th pin. with same download cable and same program i am loading in to good card and bad card.
TCK freq is 6MHZ waveform attached.
