MartinSmith's avatar
MartinSmith
3 years ago
10CL010Y BSDL File
Hello, where can I find the BSDL file for the 256 pin version of the 10CL010Y? I can find the one for 10CL010 but this is incorrect for the silicon I am using and tries to test some GND pins.
  • AqidAyman_Altera's avatar
    AqidAyman_Altera
    As we do not receive any response from you on the previous question/reply/answer that we have provided, please login to ‘https://supporttickets.intel.com’, view details of the desire request, and post a feed/response within the next 15 days to allow me to continue to support you. After 15 days, this thread will be transitioned to community support. The community users will be able to help you on your follow-up questions.
    AqidAyman_Altera
    Hi Martin,
    Do you have any more concern on this? Please let us know if there is any.
    Aqid
  • FvM's avatar
    FvM
    The 256 pin devices are migration-compatible, not pin-identical. Comparing 10CL010 and 10CL025 pinout would have clarified.
    J11 is one of the pins that has to be connected to ground in migration compatible design although it's IO in 10CL010.
  • MartinSmith's avatar
    MartinSmith
    There are multiple ones, for instance J11 in the BSDL file is entered as...
    --BSC group 87 for I/O pin J11
    "261 (BC_1, IOJ11, input, X)," &
    "262 (BC_1, *, control, 1)," &
    "263 (BC_1, IOJ11, output3, X, 262, 1, Z)," &
    But on the Intel ref design schematic (doc 150-0321321-A1) it's shown as being GND
    I know this is for the 10CL025Y version but they are meant to be pin compatible?
  • FvM's avatar
    FvM
    Which BSDL pins do you see in conflict with actual pin mapping?
    MartinSmith
    yes, but this appears to be incorrect for the 10CL010YU256I7G
