8 years ago10779 VHDL ERROR : expression is not constant
Hello guys, I am writing VHDL code in Quartus Prime 15.1 Lite Edition. I have problem when I was doing Analysis and Synthesis. The error is expression is not constant. I can use that data(a d...
8 years agoThere is nothing wrong with the code. I suspect the problem is just with quartus. And although the website you found only mentions 13.1, The problem may have persisted. I remember this issue from a long time ago (8/9 years ago), maybe it never got fixed. Have you tried in a newer version of Quartus?
Other than that, the work around is to use ifs or a case statement:
case msg_id_count is
when 3 => uart_tx_data_s <= tx_id_s(23 downto 16);
when 2 => uart_tx_data_s <= tx_id_s(15 downto 8);
when 1 => uart_tx_data_s <= tx_id_s( 7 downto 0);
when others => report "Illegal value for msg_id_count" severity FAILURE; -- simulation case to catch illegal value of msg_id_count
end case;
