8 years ago10779 VHDL ERROR : expression is not constant
Hello guys, I am writing VHDL code in Quartus Prime 15.1 Lite Edition. I have problem when I was doing Analysis and Synthesis. The error is expression is not constant. I can use that data(a d...
8 years ago --- Quote Start --- Can you post the code? Without that there is little we can say --- Quote End --- Firstly, thank u for replying my problem I added my file as attachment.You can look in the attachments. In the altera_code.PNG ; msg_id_count is variable and integer signal. I can use variable because ı want to do generic and like shift register. Actually, I dont understand why did the error occur in the 15.1 versiyon. I find my problem's solution in the altera site, you can look in the altera_problems_solution.jpg. my versiyon is updater than 13.1 altera versiyon, but THE ERROR occur when I was doing SYNTHESIS.
