9 years ago0-15 counter
Hi Guys, Can anyone help me i am nee to altera programming. Can anyone help me i am trying to write an up and down counter that counts from 0-15 with 2 bushbuttons and 2 7 segments display ...
9 years ago --- Quote Start --- EPM7064SLC84-7 that's the device i am using --- Quote End --- Ah, so not an evaluation board then? Or if it is, it is an ancient one. The Altera UP2 had a EPM7128SLC84-7 device. An evaluation board is a good investment if you can afford one, since it makes it easier for others with the same hardware to share their designs. It also helps beginners like yourself learn good coding habits. That being said, your device can be programmed to contain a counter that can blink the LED, and do the other tasks you're interested in learning, so keep going! Cheers, Dave
